335i Alpina B3s Biturbo 400 Allrad 2012 (Siko95)
Siko95
Prénom : Sylvain
Département : 60
Ma voiture : 335i Alpina B3s Biturbo 400 Allrad 2012 (Siko95)
A remercié : 73 fois
A été remercié : 37 fois
Message par Siko95 » mar. 21 nov. 2017 20:20
salut à tous,
Je fais ma présentation officielle:
Alpina B3S Biturbo ALLRAD 400 E91 de 2012 (ramené d'allemagne)
115.000 et des brouettes maintenant :]
Vous trouverez la liste de ses options suivant :
Type code: UU11
Model: 335XI (EUR)
E-F-R series: E91 LCI (LifeCycleImpulse)
Series: 3
Type: TOUR
Steering: LL
Doors: 5
Engine: N55
Displacement: 3.00
Power: 225 (306 hp)
Drive: ALLR
Transmission: AUT
Paint code: A52 - SPACEGRAU METALLIC
Upholstery code: LCSW - LEDER DAKOTA/SCH
Prod.date: 2010-10-15
S1CB ACEA / CO2 scope
S1CD Brake Energy Regeneration
S2KU BMW LA wheel V-spoke 285
S2XA Sport leather st. wheel w/ shift paddles
S4AE Armrest front, retractable
S6AA BMW TeleServices
S6AB Control, Teleservices
S6VC STEUERUNG COMBOX
S7SN Navi Business/mobile-ph.prep. Bluetooth
S8TL TAGFAHRLICHT FRONT UND HECK AKTIV
S8TN TAGFAHRLICHT UEBER LICHTMENUE EINST
S9AA Outer skin protection
SXEY ALPINA EDELHOLZ
S161 Exhaust emissions standards EU5
S203 4-wheel drive
S205 Automatic transmission
S216 HYDRO STEERING-SERVOTRONIC
S230 Extra package, EU-speciifc
S249 Multifunction f steering wheel
S258 Tyres with runflat properties
S302 Alarm system
S313 Fold-in outside mirror
S320 Deleted, model lettering
S321 Exterior parts in vehicle colour
S346 Chrome Line exterieur
S358 Climate comfort windscreen
S418 Luggage compartment package
S423 Floor mats, velours
S428 Warning triangle and first aid kit
S459 Seat adjustment, electric, with memory
S481 Sports seat
S488 Lumbar support, driver and passenger
S493 Storage compartment package
S494 Seat heating driver/passenger
S502 Headlight cleaning system
S508 Park Distance Control (PDC)
S520 Fog lights
S521 Rain sensor
S522 Xenon Light
S524 Adaptive Headlights
S534 Automatic air conditioning
S536 Auxiliary heating
S544 Cruise control with brake function
S548 Kilometre speedo
S563 Light package
S606 Navigation system Business
S612 BMW Assist
S615 Extended BMW Online Information
S616 BMW Online
S633 Preparation, mobile phone, Business
S672 CD changer for 6 CDs
S676 HiFi speaker system
S761 Individual sunshade glazing
L801 NATIONAL VERSION GERMANY
S851 Language version German
S863 Dealer List Europe
S879 Operating instructions German
S920 Alpina without registration document
S940 special equipment BMW Individual
Individual equipment
---- Processing Individual
Sign quot;BMW individualquot;
0940 Special equipment on demand
E9x Alpina Raeder 18quot;
E90/E91 Alpina B3
Aggregates or equipment differing from
standard:
- Scope engine:
N54 instead of N55 engine.
- Scope engine electric
- Scope fuel processing:
Intake silencer and air ducting as N54
(from 03/10 until 18.04.2010).
Intake silencer and air ducting Alpina
specific (from 19.04.2010).
- Scope fuel supply:
Fuel tank with 5,8 bar fuel supply pump
as before LCI (from 12.07.2010).
- Scope cooling:
Expansion tank and cooling-water pipes
as N54.
Separated radiator as N54 HP (from
09/10).
Scope radiator electric for 850W (from
17.05.2010 only LL).
09/10 for all types).
- Scope Exhaust system:
With pre-catalyst from N54 (until
28.03.2010).
With pre-catalyst Alpina specific (from
29.03.2010).
- Scope front axle
- Scope steering
- Scope rear axle
- Scope bodywork equipment:
Alpina specific air ducting brake-AKMK
(from 09/10)
- Door sill finishers
- Scope air condition
- Scope Board equipment.
0XEY ALPINA fine wood
Interior trim strips in Alpina wood
quot;Ruestermaserquot;
as interior trim strips version.
c'est une 335i avec des modifications spécifiques à Alpina :
=> piston Mahle basse compression
=> traitement vilebrequin
=> périphériques revus (pompe à essence, refroidissement additionnel, gestion ZF par alpina, Conduit venturi d'air, descente d'échappement etc..)
=> un intérieur revus sur les petits détails ainsi que le cuir
=> numéro de série bmw rayé avec numéro série Alpina en dessous :pascontent1:
un petit tour sur le pont pour checker sous la jupe de madame :ghee:
juste une fuite sur le transfert du pont avant :super: pas de corrosion , pas de trace d'accident, pas d'autres fuites à signaler :10:
Modifications à ne pas venir :
Le changement des jantes par des alpina 20" voilà c'est dit et vous me ferez pas changer d'avis :vivemoi:
Modification à venir :
entretien globale à 120.000 km (bougies,tous les fluides, vidange boite, vidange transfert etc...)
Prise compression et contrôle étanchéité des 6 cylindres
vérification bobines
contrôle performances au banc de puissance
remplacement des amortisseurs (pas encore défini mon choix) car kilometrage + configuration gt = Youpiiiiiiii dansons la cariocaaaaaaaaaa, c'est biiiiiiiiiien faites tous comme moiiiiiiii :mdr2:
installation durites de frein aviation BF GOODRICH
libérer le moulin (entre les normes d'homologations et la politique BMW M / Alpina) qui est actuellement amputé d'environ 40/50cv et le couple en conséquence (environ 40/50nm pour pas dépasser la limite de la boite)
j'aimerai bien mettre en place un système de valves en Get out pour libérer le chant pendant le loisir :flechedamour:
intérieur leds , leds pour les anneaux, quelques bricoles de codage (je réfléchis éventuellement à intégrer grand écran avec les dernières générations de Idrive je verrai en fonction du budget X| )
cette voiture sert de familiale et loisirs circuits/balade ocassionnels
Voilà voilà si vous avez des questions n'hésitez pas :cote:
MAJ 08/02/2018 :pausecaffé: :
Peinture étriers Or fait 23/03/2018
Installation cales doubles boulonneries +12mm AV et +20mm AT fait 23/03/2018
Commande St suspensions + durite de frein GOODRICH aviation OK fait 23/03/2018
Entretien des 120.000 km + prise compression moteur + suspattes/geo/para + Durit Frein + réparation fuite transfert AV fait 23/03/2018
Passage au banc effectué : 320cv aux roues pour 394cv en sortie vilo ( environ 23% pertes cohérentes dûes au Xdrive )
PASSAGE BANC ALPINA B3S BITURBO.pdf
(229.32 Kio) Téléchargé 16 fois
Modifié en dernier par Siko95 le jeu. 22 mars 2018 21:17, modifié 3 fois.
jo318ti
Département : 57
A été remercié : 14 fois
Re: 335i Alpina B3s Biturbo 400 Allrad 2012 (Siko95)
Message par jo318ti » mar. 21 nov. 2017 20:24
Comme déjà dit dans ton autre post: MAGNIFIQUE!!
Soigne la bien :coeur:
Sinon.................... :ange: des jantes Alpina.......... :diable: ::d
Ces utilisateurs ont remercié l’auteur jo318ti pour son message :
Siko95 (mer. 22 nov. 2017 00:29)
Classement : 6.25%
Prénom : Remy
A remercié : 178 fois
A été remercié : 466 fois
Message par ReMo38 » mar. 21 nov. 2017 20:32
Pareil, comme déjà dit elle terrible même si je m’attendais à plus venant d’une alpina :super:
L’essentiel tu l’a et quel plaisir ça doit être à conduire ce démon à gueule d’ange :diable:
Et des Alpina en 19" ? :mrgreen: :hehe:
LeBosch
Prénom : David
Ma voiture : Mon 320d e91
Donateur depuis le : 08 juin 2017
A remercié : 418 fois
A été remercié : 181 fois
Message par LeBosch » mar. 21 nov. 2017 20:43
Très beau missile , sa m'impressionne le nombre de CV !
par contre pour moi je me répète :
- logo alpina extérieur carrosserie, jante etc
- jante alpina
Siko95 (mer. 22 nov. 2017 00:32)
Classement : 6.25%
Selasss
Prénom : Nico
Département : 25
Voiture : 318i
Modèle : E30
Année du véhicule : 1990
Ma voiture : Mégane RS2
E30 318is
A remercié : 90 fois
A été remercié : 53 fois
Message par Selasss » mar. 21 nov. 2017 21:10
Sympa ce break de chasse.
Je trouve dommage que les éléments de carrosserie soient si "fades"! Le PC arrière est celui de base!!!
Ces utilisateurs ont remercié l’auteur Selasss pour son message :
Classement : 6.25%
CAP
Prénom : Antoine
Département : 57
Modèle : M240i
Année du véhicule : 2016
Ma voiture : 240i
Donateur depuis le : 08 juin 2018
A remercié : 12 fois
A été remercié : 36 fois
Message par CAP » mar. 21 nov. 2017 23:22
Très belle auto que tu as là, je suis un peut du même avis que Selass je trouve malheureusement les éléments extérieurs fade ça ressort pas vraiment dommage venant d'Alpina.
Ces utilisateurs ont remercié l’auteur CAP pour son message :
Siko95 (mer. 22 nov. 2017 00:34)
Classement : 6.25%
"Il est dur d'échouer, mais il est pire de n'avoir jamais tenté de réussir.” - Franklin Delano Roosevelt
ScuY
Prénom : Yann
Département : Moselle
Modèle : F36 (GC)
Ma voiture : S5 sportback
A remercié : 360 fois
A été remercié : 170 fois
Message par ScuY » mar. 21 nov. 2017 23:31
Toutes les Alpina sont sur base "normal" et pas le pack M.
Mêmes les nouvelles B3/B4.
Siko95
Prénom : Sylvain
Département : 60
Message par Siko95 » mer. 22 nov. 2017 00:31
ReMo38 » mar. 21 nov. 2017 20:32 a écrit :Pareil, comme déjà dit elle terrible même si je m’attendais à plus venant d’une alpina :super:
Raté elles sont en 20" les alpina origines ! Même joueur rejoues :hehe:
Siko95
Prénom : Sylvain
Département : 60
Message par Siko95 » mer. 22 nov. 2017 00:33
Selasss » mar. 21 nov. 2017 21:10 a écrit :Sympa ce break de chasse.
Pour ça il y a les M ;)
Siko95
Prénom : Sylvain
Département : 60
Message par Siko95 » mer. 22 nov. 2017 00:37
ScuY » mar. 21 nov. 2017 23:31 a écrit :Toutes les Alpina sont sur base "normal" et pas le pack M.
Tout à fait à l'exception de la face avant spécifique Alpina !
Je trouve que cela fais son charme à l'inverse qui a plus de chances de surprendre de par sa discrétion :cote:
Prénom : Remy
Message par ReMo38 » mer. 22 nov. 2017 00:38
Je sais bien, c’est pour t’embêter vu que dans le 1ère message tu dis "pas de jantes Alpina en 20" " alors moi je te dis "et en 19" ? " :langue2:
Siko95
Prénom : Sylvain
Département : 60
Message par Siko95 » mer. 22 nov. 2017 00:46
:jesors: :gene:
coudepoulet
Pilier du Forum
Pilier du Forum
Département : Ici et là
Modèle : Z4
Ma voiture : La poulaillère
A remercié : 89 fois
A été remercié : 91 fois
Message par coudepoulet » mer. 22 nov. 2017 06:56
Jolie voiture... :super:
Ces utilisateurs ont remercié l’auteur coudepoulet pour son message :
Siko95 (mer. 22 nov. 2017 22:31)
Classement : 6.25%
A remercié : 31 fois
A été remercié : 249 fois
Message par airliner33 » mer. 22 nov. 2017 09:05
Même pas de photos de dessous ! alors que tu en parles en premier temps (déception !)
Moi je dirais qu'elle est pas mal pour une caravane :mrgreen: c'est pas mon style mais si c'est le tien alors :amen:
C'est rare les alpina, serait-il possible d'avoir des photos inter/exter comme il se doit et de dessous :D
Go-fast
Prénom : Christophe
Département : Belgique
Voiture : M3
Modèle : E36
Année du véhicule : 1996
A été remercié : 11 fois
Message par Go-fast » mer. 22 nov. 2017 09:21
Sympa, mais j'accrocherai jamais ces rajout de pare choc Alpina.
